how to keep water out
Old Jun 28, 2010 | 11:53 AM
ratliff7189's Avatar
Default how to keep water out
what things do i need to water proof my 2006 rancher 400 at i do alot of river rideing and some times it cuts out i have the plug and the angel sensor sealed but that is it
Old Jun 28, 2010 | 11:51 PM
fourtraxhonda300's Avatar
..thats pretty much it, unless you need your air intake and exaust pipe higher. they make snorkles for that.
Old Jun 30, 2010 | 12:39 PM
TexasRoadlawyer's Avatar
No Ruts, No Glory
not hardly....
You have several carb vent hoses that need to be secured above your "water line" or piped into your snorkeling system.
If you have a belt-drive auto tranny, you will have to snorkle the intake and "exhaust" vents for the transmission (probably doesn't apply to your 400)
You also have front and rear differential vents that should be snorkeled, and some drum brake systems have vents that should be snorkeled.
You should also coat all electrical connections with dielectric grease
Customer Service #1
May 15, 2020 08:46 AM
Alex G.
Sep 11, 2017 11:38 PM
panicmanic
Sep 28, 2015 12:59 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
