Engine coughing...
Old Jun 30, 2010 | 11:36 AM
Chaosin1983's Avatar
Banned
Default Engine coughing...
I seem to have a little problem with my '05 450R, while pushing the throttle hard it will sometimes cough or tries to die if I don't let go of it. I first experienced this problem while running it cold, I've been suggested that I should let it warm up a few minutes before pushing it, but this weekend it did it again after a couple of hours of riding. It only did it a couple of times and then it went back to normal. What could be causing this? The engine is completely stock.
Old Jun 30, 2010 | 12:23 PM
JeffinTD's Avatar
Without being able to hear what it is doing it is hard to say.
Since it happens at high throttle, I'd suspect a fuel restriction (dirty screen, some garbage in the float bowl).
Old Jun 30, 2010 | 12:26 PM
Banned
It doesnīt sound wierd, and itīs not constant, it just tries to die, and itīs only for a couple of seconds, Iīll let go of the throttle and push again and it will be ok...
Old Jul 1, 2010 | 08:02 AM
JeffinTD's Avatar
I'd say check out the fuel screen, and the carb.
Old Jul 1, 2010 | 03:31 PM
Canadian07trx450er's Avatar
It could be something like that but with my 450r i always let it run for maybe 2 minutes before giving it a lot of gas and then putts around a bit then drive it hard and see what happens. because the same thing can happen to mine if reved out right away.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
austinwhitton
Aug 11, 2015 06:21 PM
Jul 30, 2015 09:39 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
