Honda 400ex ported bottom end
your post is a bit confusing, by ported, do you mean it has drilled ports for the oil lines? other than that, you only "port" the top end, the intake and exhaust runners. the 400ex should have a small factory oil cooler on it, you could just attach hoses to those lines and run them to a bigger cooler, seen that done on several 400s, you can even do an add on to a 300ex by cutting into the oil line that goes across the top of the motor, and run lines to a cooler.
