Brakes locked up, or something, Honda TRX300
Ok...got that done..it's a no go. it was hard to find cuz it was behind the bolts that hold that skid plate (I guess that's what it is) on.
Now what? I can spray as far as the WD40 red tube will spray, which isn't very far really, into there.
I wonder if just letting it set overnite would help?
dunno....
thoughts? prayers?
dunno....
thoughts? prayers?
![Big Grin](https://atvconnection.com/forums/images/smilies/biggrin.gif)
#15
Well, that's got a solid axle in it so I would say the axle is broken. Hate to say it, but that's what it sounds like. Take a look at this picture. This is a 1998 TRX300.
Motorcycle Parts, ATV Parts, PWC Parts | DGY.com | Yamaha, Honda, Suzuki, Kawasaki, Can-Am, Sea-Doo, Ski-Doo | Motorsports Parts, Accessories, Apparel
As you can see, the axle is one solid piece. So, if the left wheel is turning, and the right isn't, the axle is broken and there's probably a piece of gear tooth or something inside the differential that has wedged in somehow and is keeping the right wheel from turning. Take the differential fill cap off and look in there and see if anything looks out of place. I hope I'm wrong about this. I have never heard of an axle actually breaking but I hear about them bending. But, I suppose if the original problem was a tooth that broke in the diff., it might break the axle inside without bending it.
#18
Another thought just occurred to me. When you turn the left rear wheel, does the left half of the axle turn or is the wheel turning and the axle is not? If the axle is not turning, the spline between the wheel hub and the axle is stripped. Usually it's the hub spline that strips, not the axle spline. The hub is softer. If that is the case, then we're back to the brake being the problem. Let's hope so.
#20
No not sure but all the times I've messed with old Honda's it's been the brakes. Not saying it can't happen I've just never ran into that.
