honda 84 250r crank case problem
I was out riding my honda 84 250r yesterday and I parked it for a few minutes and then went to go ride it again and I went to kick it over and the kick start wouldnt catch anything. then i clicked it in first gear and it like didn't catch it would still roll like it was in neutral. really wieird it was running %150 just before i parked it. and help would be awesome I was hoping to go riding later today with my cousin.
I guess i would remove spark plug and put an straw r something soft in the plug hole then move the kick start and see if piston moves, if does sounds like the piston and rings are stuck causing no compression, if piston doesn,t move than kickstarter bearing is bad....... Good Luck....
