front brake parts question
Old Aug 6, 2010 | 10:21 PM
Specta's Avatar
Default front brake parts question
Looking at the parts Fiche it lists the shoes as #1 and includes all 4 shoes and the return springs. Do the tension pins, caps and seals come with the shoes too?? They too have a #1 by them besides the individual part numbers.
I can't beleive that I only got 13,000 miles out of my OE front brakes, I'll thank the ESP for that. Looks like the rear still has some miles left.
Old Aug 7, 2010 | 09:17 AM
TLC's Avatar
TLC
Yes, P#06450-HN5-671 $40.
OEM motorcycle and ATV parts from Honda, Yamaha & Polaris – Cycle Parts Warehouse
I have to change the fron shoes on a my old 450 Foreman today (Bottom pic),I got all 4 shoes P# 06450-HN0-A00 off ebay for $25,my dealer wanted $90! They look like same set up as yours.
450 FOREMAN
Old Aug 7, 2010 | 11:36 PM
Specta's Avatar
thanks TLC, my dealer wants $37 for the front shoes and $31 for each wheel cykinder. I was jsut curious oif the hold down pins came with them, I'll replace them either way. I'm going to replace all the seals and wheel cylinders too.
Old Aug 8, 2010 | 01:20 AM
KNOWSALOT's Avatar
The Facility
Specta,
Near as I can tell, you should be getting all of those pieces in the brake shoe kit if you are buying Honda OEM brake shoes. And the next time you want super prices on Honda OEM stuff, let me know and Ill see what I can work out for ya.
Patrick
Old Aug 8, 2010 | 09:07 AM
TLC's Avatar
TLC
Well I finished the job yesterday,pretty easy to change front shoes, just remember turn the front cylinder adjuster collar counter clock wise and the rear one clockwise to tighten the brakes. Always wondered what that red rubber plug was for on the rim.
Bad news is one wheel bearing is shot. I have changed them on disk brake ATVs but not a drum brake ATV,not sure if that makes the job harder.
Old Aug 8, 2010 | 09:52 AM
Specta's Avatar
The red plug is an inspection hole to see the shoe lining.
I might replace the front wheel bearings too. Seems like once you’re in there other things start giving you trouble too.
I really like trouble free riding and I believe that preventative maint is the only way to do it.
Bearing, seals and a ball joint $65, a complete knuckle assembly $81.
I think I'll stick the the bearing and seals for $51.
Old Aug 8, 2010 | 09:57 AM
TLC's Avatar
TLC
I used it to adjust the brakes with a flat head screw driver onces I got the drum back on.
Old Aug 8, 2010 | 10:30 AM
Specta's Avatar
Nothing better than a two-purpose hole. LOL
Old Aug 8, 2010 | 10:31 AM
Specta's Avatar
Originally Posted by KNOWSALOT
Specta,
Patrick
Thank you very much, I really appreciate that, both the answer and the offer. And I will be buying Honda OE parts.
Old Aug 8, 2010 | 10:34 AM
TLC's Avatar
TLC
It had me stumped for a bit., how would I adjust and spread the shoes out then be able to get the drum back on. Thanks for the hole Honda. LOL
AK47KID
Jul 23, 2015 09:21 PM
scaldwellk
Jun 19, 2015 05:08 PM
gdmclnh
Jun 13, 2015 05:32 PM
CountryMiles
Oct 25, 2000 01:03 AM
JD250R
Sep 21, 1999 05:52 PM
