300ex questions
Old Aug 14, 2010 | 08:32 PM
longee13's Avatar
Default 300ex questions
I put a 14 tooth front sprocket on my 300ex and the little chain guide in there that bolts to the sprocket cover is making noise like metal im not sure if i need a new one or if its cause the sprockets bigger. also i was wondering if anyone new if the g force front wheel spacers are any good i got an extended axle and cant afford the extended a arms
Old Aug 14, 2010 | 08:56 PM
sdm111's Avatar
2 strokes or 4
Since you went to a bigger sprocket the chain is rubbing on the chain guard ( case saver ). Whatever you do don't take the case saver off, if you do and you throw the chain the chances are great that the chain will bust a hole in your engine. Get a dremel or something and shave just a hair off the case saver just enough for the chain not to rub. About the 2nd question don't know never had any.
Old Aug 15, 2010 | 08:10 AM
95wolv's Avatar
There is a way to afford wider a arms, just use 400ex a arms, bolt right in, gives you about an inch on each side, then while you are on ebay buying a arms, get the 400ex shock mount kit, and a pair of good used 400ex shocks,along with the longer tie rods, I'm pretty sure you can just use 400ex rods, thread right in,or they do make longer rods for the 300. Not as fancy as a 1000 dollar racing set up, but rides, handles, way better than stock 300ex set up for a fraction of the cost.
Old Aug 16, 2010 | 03:39 PM
hillbilly_racer's Avatar
What he said. Don't use front wheel spacers. They will make the front end wider but the it will make the handling terrible. And yes, the stock 400ex tie rods will work. If you can afford it, this a-arm setup with some aftermarket shocks works really good.
Old Aug 18, 2010 | 02:25 PM
longee13's Avatar
sounds good thanks
bigred20653
Oct 2, 2015 10:05 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
ScopeZ_
Sep 13, 2015 07:55 AM
Wiley wolf
Sep 7, 2015 08:32 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
