300ex wont stay running need help
Old Aug 17, 2010 | 09:09 PM
hondarider123's Avatar
Default 300ex wont stay running need help
i have a 95 300ex it will only run if the throttle is wide open but then it wont get to its highest rev. and its sputtering the whole time. i cleaned the carb. all the jets are clean its got good gas new spark plug and its getting plenty of gas and when i let off the throttle it cuts off and black smoke blows out the exhaust and the carb. sometimes anyone got any ideas of what it could be?
Old Aug 17, 2010 | 11:08 PM
JeffinTD's Avatar
Is the air filter caked with gunk, and is the float working properly? Is the enricher/choke working correctly?
Unless the smoke is actually bluish and smells of oil, I think you are either getting no air or way too much fuel.
Old Aug 18, 2010 | 04:22 PM
the air filter is new and the enricher/choke is working right but in not sure about the float. if i have the throttle wide open the carb shots a mist of gas out of the intake constantly. and it wont run with the choke on
Old Aug 18, 2010 | 05:19 PM
hillbilly_racer's Avatar
Check the jet needle on the carb slide.
MikeyBoyesq
Nov 27, 2020 02:44 PM
fullprice54
Jun 18, 2015 09:44 AM
NONEtooSMART
Jun 17, 2015 08:48 AM
jayking232003
Jun 9, 2015 02:54 PM
Hondaislife
Sport Quads
May 27, 2015 05:38 PM
