need help with rear end in rancher 420 2009
Old Oct 4, 2010 | 04:15 AM
JeffinTD's Avatar
Is it something you are using a bearing puller?
Can you post a photo?
Old Oct 5, 2010 | 04:15 PM
danmckennat's Avatar
well i got the lock nut and ring stopper out but the needle bearing will not come out, and when we got lock nut out it stripped the threads so i think at this point i am just going to order new rear end
Old Oct 5, 2010 | 05:36 PM
JeffinTD's Avatar
Maybe you could find a good used one?
Old Oct 7, 2010 | 08:34 PM
just ordered a new rear end so hope that fixes the problem
Old Oct 13, 2010 | 05:33 PM
  #15
still waiting for the new rear end guys, as soon as get it and install it i will let you know what happens
Old Oct 17, 2010 | 11:11 AM
  #16
parts are now on two week back order so will lets you guys know
Old Feb 13, 2011 | 11:49 AM
  #17
just an update still waiting on new rear end going on six months now
Old Feb 15, 2011 | 12:59 PM
  #18
jrubicon's Avatar
Hey Dan?
i just got a new 09 Rancher 420, althought mine is auto and IRS,
whats your email? i wish i knew other locals to ride with, im in norcal.
I hope you get your atv fixed dude.
jason
Old Aug 11, 2015 | 08:54 AM
  #19
stumpy957's Avatar
Default 420 Rear Diff
Did you ever figure out what was causing your issues with your rear end? It is the pinion bearing going out. We have (4) of these and all we do is work on the rear ends. There is no way to keep the mud and water out of the rear end on these and it takes the pinion bearing out. I continue to try different things like seals, turning seals around and now I am going to try a few more things. I can't believe Honda has such a problem child for nearly 10 years when they are such a reliable machine. If anyone has any ideas or remedies to keep the water & mud from getting past the pinion seal, I would sure appreciate it!!!
Old Aug 11, 2015 | 01:04 PM
  #20
greg74's Avatar
I assume since this was almost 5 years ago, that he probably doesn't have it anymore. I have heard bad things about the Rancher 420 rear ends. I'm glad I never bought one. The 350 had less power but it would run forever.
