Honda TRX300
Old Sep 21, 2010 | 01:46 PM
ARE_BSA's Avatar
Default Honda TRX300
I have a '91 TRX 300, the carb is bad and cant afford to fix it, keeps fouling out spark plugs. I have heard that you can completly block off carb with metal plate and run machine like that. Is this true
Old Sep 21, 2010 | 01:53 PM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums.
That would be false. Blocking the carb means no air or fuel (if you completely block it) and it will not run. Are you thinking of a two stroke that has an separate oil tank?
Old Sep 21, 2010 | 02:03 PM
ARE_BSA's Avatar
thanks
not the sharpest or mechanical inclined, don’t know about the two cycle part........ over the weekend the machine would not start, i removed the spark plug and it smelled of gas, put new plug in and the machine fired right off...
Old Sep 21, 2010 | 02:27 PM
DODGE57HEMI's Avatar
Mopar Man!
Welcome!
Old Sep 21, 2010 | 06:12 PM
mikel1's Avatar
Welcome to the Forum!
You can try a carb rebuild kit, it's alot cheaper than a new carb. You could also try going with a slightly hotter spark plug and see if that helps. How many turns out on the pilot jet do you have?
Old Sep 22, 2010 | 08:11 AM
ARE_BSA's Avatar
not sure about a pilot jet?
Old Sep 22, 2010 | 09:10 PM
mikel1's Avatar
On this link go to the carb schematic the pilot jet will be #5- screw set from the lightly seated position it should then be turned out 2 1/2 turns
1991 Honda TRX300 FOURTRAX OEM Parts, 1991 Honda TRX300 FOURTRAX OEM Motorcycle Parts - BikeBandit.com
Old Sep 23, 2010 | 07:52 AM
ARE_BSA's Avatar
I'll take a look at that, also i think there is something wrong with the idle also, i know i cant seam to get it set to run right
Old Sep 23, 2010 | 06:28 PM
ryan451's Avatar
Default 1996 honda trx300
I have a 1996 Honda TRX300 and it will start and idle fine, but when i push the throttle it quits. When in gear and pushing the throttle will try to pull but then quits. I have changed the gas and checked the spark plug and the plug appears fine. Any Suggestions
Old Sep 23, 2010 | 10:10 PM
mikel1's Avatar
If equipped with a fuel shutoff screen then make sure it's clean and make sure the o-ring above the screen is not breaking off. Clean the carb really good and then see if that helps. It doesn't take much fuel to idle but takes more fuel at a faster rate when pressing the throttle. If you have ever been low on fuel in the tank it will still idle fine but when you press the throttle it will shut off.
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
rgjackson
Sep 17, 2015 11:21 AM
wendal
Sep 15, 2015 01:50 PM
Jason Campbell
Sep 7, 2015 02:25 PM
