Improving a 300ex
Old Feb 25, 2011 | 11:00 PM
TexasRoadlawyer's Avatar
No Ruts, No Glory
If you want to spend some cash, DIRTWHEELS mag did an article on hotrodding the 300EX to where it would flat out run away from a stock 400EX. Four Stroke Tech is the company to call as the article featured their work.
Old Feb 26, 2011 | 06:29 AM
95wolv's Avatar
Originally Posted by RighteousEX
Supposedly the stock header pipe is very restrictive. since your going to be buying an exhaust you might as well spend a little extra on a full exhaust system.
VERY good point, the stock head pipe is about the size of your finger inside,definately go with a full pipe/silencer set up, but also get some high temp exhaust tape and line the inside of the fender by behind your right leg, the aftermarket pipes run closer, and are thinner walled than stock, so the extra heat will burn or melt the plastic in that area, saw a lot of modified 300ex s with a burn spot there, put some aluminum cloth type heat sheild on the back of the fender in that spot on my son's 300ex, never had a problem.With the exhaust, either run with no lid and a Outerwears cover on the top, or punch a few holes in for better intake, the stock air box is only fed through 2 frame tubes, not a lot of air for performance gains, then jet up for the extra flow, and you will be good. I went up a size on the pilot as well, helps starting, and off idle acceleration, a bit lean from the factory.
Old Feb 26, 2011 | 02:44 PM
RighteousEX's Avatar
What was the date of the dirt wheels magazine that did the 300ex buildup? I'd like to read that
Old Mar 4, 2011 | 10:56 PM
sportman400's Avatar
FMF Powercore 4 complete exhaust system. I paid $230 shipped on Ebay. Open up airbox, Uni or K&N filter and rejet. Also have the stock gearing with 20" Holeshots on rear. If you want more involved, I also put in a 11.5 Wiseco piston and a stage 1 cam. Perfect for woods and trail riding. Lots a torque.
Old Mar 11, 2011 | 07:09 PM
  #15
CWhyt's Avatar
I bought a FMF powercore 4, do I need a full jet kit or just some
Old Mar 11, 2011 | 07:34 PM
  #16
95wolv's Avatar
I would go up one size on the pilot jet, and if you are running without the lid on the air box, 2 sizes up on main to start, then do a run and check your plug. Just buy some jets at the dealer, no need for a kit.
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
ScopeZ_
Sep 13, 2015 07:55 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
antiguogrumete
Sep 5, 2015 03:41 AM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
