recon missing
Old Apr 6, 2011 | 05:56 PM
2003beastrecon's Avatar
Default recon missing
ok if i run my needle jet back in it get worse like it wants to spit and sputter worse if i run it out almost to were i can c the first o ring it runs better does this mean i need to put a bigger jet in.
Old Apr 7, 2011 | 02:43 PM
95wolv's Avatar
have you changed the intake or exhaust by adding a freer flowing filter, or a slip on muffler? or are you running without the lid on the airbox? If not, jetting is not your problem, you probably have a dirty carb, and need to clean it and put the needle back to stock and try it from there. On a stock motor, unless you change elevation by quite a bit, you should never need to rejet .
95wolv
Sep 27, 2024 12:00 PM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
tysonbully
Sep 28, 2015 02:30 AM
Ridgebackguy86
Sep 19, 2015 12:48 PM
Jason Campbell
Sep 7, 2015 02:25 PM
