250r, how good are reed spacers?
Old 03-14-2001, 01:43 PM
stephen's Avatar
i own an 86 trx 250r, i have fmf fatty & power core 2 silencer, wiseco piston, carbon-tech reeds. does a reed spacer add sufficient enough power to make it worth the 20 bucks???? is the power noticeable? thanx
Old 03-14-2001, 01:55 PM
scottbl99's Avatar
as a reliable engine builder ...CURTIS SPARKS has said do not put them on they only hurt the engine for power...spend 45 dollars and get a 98 cr reed cage is what he said it is just like the paramid reed cage and it boost your power and increase you r horse power
Old 03-15-2001, 01:13 PM
stephen's Avatar
do you mean the reed cage off of a 98 honda cr dirtbike??? if so, do the bolt patterns and everthing match up, or is there and mods necessary? is this cage just as good as the aftermarket ones? how much of a power increase should i expect? one last question, i want to get a bigger carb, i have fmf pipe & silencer, K&N w/lid removed, and hopefully a bigger reed cage,,, what would you recommend? i was thinking about a keihin 38mm pwk air striker. i'd hate to get one that is too big, but at the same time, i don't want one that isn't large enough for the portwork i plan to do later in the future. thanx a million
Frisky2050
04-09-2020 11:19 AM
coldnorthpol
07-14-2015 11:22 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
07-08-2015 02:16 PM
Robbbb55
07-08-2015 02:11 PM
Technical and How-To Articles
07-02-2015 01:34 AM
Quick Reply: 250r, how good are reed spacers?
