2002 450 foreman rear end
Old Jan 2, 2012 | 09:16 PM
200es's Avatar
Default 2002 450 foreman rear end
i have a 2002 450 foreman and the rear end went, does anyone know if the rear end out of a 500 rubicon not sure of the year will fit my foreman?
Old Jan 3, 2012 | 05:36 AM
Oldsman67330's Avatar
I looked into that once for my 2000 and was told they are different, wasn't told what was different about them, just that they were different. I'd like to compare them side by side, count splines, check bolt holes, etc. What went bad on yours? The bearing kits aren't too bad of price and the ring and pinion is much cheaper than buying the whole gearcase. I've had mine a part and put new bearings in it, they aren't bad to work on. I want to replace mine because the sealing surfaces on the ring gear are in bad shape and it won't hold seals anymore.
Old Jan 3, 2012 | 05:58 AM
200es's Avatar
The axle was welded to the rind gear and snaped in half, damaging the axle houseing,
Old Jan 3, 2012 | 08:45 PM
Sounds like reason enough to want to change it out lol
greg74
Sep 10, 2019 03:03 PM
bigred20653
Aug 31, 2015 12:41 PM
BigT137
3) General Discussions..
Aug 19, 2015 12:09 AM
Kodiak-vic
Jul 29, 2015 03:06 AM
Jul 22, 2015 05:00 AM
