1998 honda trx 250 recon
Old Mar 4, 2012 | 09:17 AM
thomas0591's Avatar
Default 1998 honda trx 250 recon
I have a trx 250 recon 1998 model. I am having a problem when I give it gas when its in gear it wants to bogg down and cuts off. It runs fine in neutral and when its cold but once it warms up it has the problem. I have cleaned the carb about 4 times now it soaked over night in seafoam, I have installed a inline fuel filter and changed all vaccum lines and fuel lines. I recently read something about maybe adjusting the valves if this will help please let me know. Thanks Anthony
Old Mar 5, 2012 | 03:20 PM
thomas0591's Avatar
Is there anyone who can tell me anything?? I tried the valves and still the same I have ordered a new carbueator and am going to try that. Will let everyone know if it works.
Old Mar 6, 2012 | 06:42 AM
budedm's Avatar
You say it runs fine cold but not when it's warm? I have to think it's the carb. The new one will probably solve the problem but you probably didn't need a new one. Carbs have lots of small ports in them that soaking won't clean. You need to clean those ports with small wires etc. And compressed air. It could also be a coil breaking down when it's warm. But, I'm betting that a new carb will do the trick. Let me know what happens. I have a 99 Recon.
Old Mar 6, 2012 | 07:07 PM
thomas0591's Avatar
the new carb didnt do it and the coil is not the problem when its in neutral its fine I can rev it as high as I want. but in gear its a problem. from the looks of it its losing spark in gear at higher rpms so im going to put a new cdi box on it and see if that fixes it.
Old Mar 6, 2012 | 07:27 PM
budedm's Avatar
CDI is the next thing I was gonna suggest. Hopefully that's it because they are $$$ and you can't return them.
Old Mar 13, 2012 | 01:38 AM
thomas0591's Avatar
The cdi box did it. In neutral it ran fine but in gear when you reved it about half way up the fire quit. But the new carb has helped also.
Old Mar 13, 2012 | 06:09 AM
budedm's Avatar
Great. Let's go ridin. Brown Mtn opens in a few weeks.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
Jason Campbell
Sep 7, 2015 02:25 PM
Slagpolaris
Sep 5, 2015 09:41 PM
