300ex wont start.
Old Mar 15, 2012 | 08:44 PM
r0ckstar850's Avatar
Unhappy
okay so i figured out i shortened the battery
Old Mar 15, 2012 | 10:35 PM
is there a way to add an custom ignition
Old Mar 16, 2012 | 04:56 AM
Jaster94's Avatar
the switch? sure, it's a matter of simple circuitry that has to be complete.
Old Mar 16, 2012 | 09:03 AM
well i have these two wires and every time i attach an switch it ends up touching the metal handle bars and shorting out my battery and tips to help meName:  IMG_10501.jpg
Old Mar 16, 2012 | 10:54 AM
  #15
budedm's Avatar
Are those to the kill switch? If so, it may be a bad switch because those wires look to be in good shape.
Old Mar 16, 2012 | 01:26 PM
  #16
its not an bad switch its just that my handlebars dont have any protection and the kill switch end up touching it and shortening out my battery so temporarily i taped these wires to the front.But i need an better idea
Old Mar 16, 2012 | 03:09 PM
  #17
budedm's Avatar
Can you either wrap the handlebars or the wire with electrical tape?
Old Mar 16, 2012 | 03:24 PM
  #18
if i leave them taped together will it ruin something
Old Mar 17, 2012 | 09:09 AM
  #19
bluebead442's Avatar
the neutral switch is on the right side of the engine underneath the clutch casing, its covered by a lil metal plate holding on by 2 1/4 inch bolts remember not to switch the 2 connections because the reverse rev limiter is also in there..if you switch them you will kno lol. you wont go past 5 kmhr if that happends reverse the connections.. i usually redo all my wiring connections during the winter so i can avoid the same problems your experiencing. I have in some cases had that prob and got so frustrated being 30 km from home i used my house key to jump the celinoid..wear a freaking glove if have to do this lol..but in the end all of you guys are right there is a neutral switch on the 300ex and its more than likely a wiring issue which is not uncommon with these quads..
Old Mar 17, 2012 | 09:14 AM
  #20
also for your wiring connections try and solder those conxx if not use proper male/female conxx but also put dielectric grease ontop of the conxx and also use heat shrink covers the whole conxx plus a few invhs of wiring..remember to put the heat shrink on firts b4 the conxx or you will swear at yourself.. my quad would quit last year everytime i switched on my highbeams..that was a pain especially at 1am...300ex's are great trail machines..the engines are almost bulletproof..iv had mine for years and 3 ppl had b4 me so who knows what they did to it..but still runs strong..good luck keep us posted..happy riding.
Scooter's Shop
Oct 9, 2015 02:09 PM
2many2ride
Sep 27, 2015 04:35 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
ScopeZ_
Sep 13, 2015 07:55 AM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
