Help with a Rubicon
Old Mar 21, 2012 | 03:45 PM
Hollow Handle's Avatar
Default Help with a Rubicon
I have a 2009 Honda Rubicon 500 atv. There are two things I would like to work on. It is a little hard to start and idle when it is not warmed up. I would assume this "cold natured" issue is carb. I have cleaned out carbs on other bikes before. Anything hard or different about the Honda carb?
Also, there is a constant whine or low squeal somewhere in the rear end when the bike is moving. It is not very loud but I do not anything like that noise on my Rancher. I know that is not a lot of info to go on but does anyone have any ideas on where to start? Brakes, bearings, something worse?
Thanks
Old Apr 3, 2012 | 01:51 PM
Deeperinthabush's Avatar
Default Rubicon problems
As to the hard to start trouble,remove,clean the carb,especially the pilot jet itself,inspect the electrical connection on the carb for the carb warmer,test it for continuity...Honda carbs are simple to work on,as simple as any other as the major atv manufacturers all use 2-3 major brands of carbs which are all pretty much alike respective to the carbs brands...As to the rear noise...Check the rear brake lever to see if it is releasing properly when you let off the brake pedal,or left hand lever..If not,tear the rear brakes down,and remove the lever,emery cloth the shaft where it rides inside of the bushing inside of the brake backing plate,and then lightly clean the bushing itself,lube shaft,and bushing up with a marine type grease,reassemble,check for free smooth revolving action with zero sticking,or drag,install new brake shoes as the old ones are prolly shot,or crystallized due to dragging,reinstall the drum,and cover,adjust the brakes to barely dragging at all when axle is spun...Remove drain plug from rear differential,drain gear oil,inspect it for bits,parts,metal pieces,etc...If it is nothing more than a little fine metal particles from normal wear n tear,refill it with hypoid 80 gear oil the specified amount by your manual,or go to hondaatvforums dot net,and download the free e manual for your model to find the proper amount if you don't already have it...Whining noise to me sounds like gear lash issues,squealing is more of a brake dragging,dried out,or metal to metal brake noise......
shimanok2
Jan 29, 2016 07:37 PM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
colt1126
Aug 18, 2015 10:38 PM
