What to look 4 in a 250R
Old Mar 18, 2001 | 09:45 PM
avc8130's Avatar
I am going to look at an 87 250r on Tuesday and I was wondering what areas I should pay special attention to. The quad is "all original" except for a DG pipe and silencer. He says its in mint condition and is asking 3900 for it, is that good? Thanks for all the help.
Anthony
Ditched the Warrior, time to get a real machine!
Old Mar 18, 2001 | 10:19 PM
fmfblaster's Avatar
You should look for cracks in the fram in these aears front motor mounts, rear motor mounts( by the swing arm) cracks in the swing arm by the axle carrier or any type of crack in the fram or swing arm. That's not a bad price because i bought my 86 all stock except for a fmf silencer.
Old Mar 18, 2001 | 10:48 PM
ugly's Avatar
Unless it is mint I wouldn't pay that much for it.I would say 3500 at the most.
Also look for crack around the steering stem mount,where the seat/fenders mount,where the swingarm connects on the frame,upper shcok mounts,check all the wheel bearings,Make sure it goes in nuetral easily,condition of chain and sprockets.Take it for a spin and check all the gears,try to get the clutch to slip and listen for any strange noises.
I know this sound like alot but as you know 250r's are riddin hard and I am sure you don't want to spend all your money and then end uo having to replace stuff
I payed 2500 for my 86 and it was ALL original.From the grips to the wheels and tires.It was and still is in pretty good shape.No cracks all good bearings.Only prob is a slight oil leak.
86 trx250r wiseco .020 piston,boyesen reeds,FMF gold series fatty pipe,power core 2 silencer,Dg alloy series nerfs,Jd performance +2 A-arms,Durablue eliminator 2+2 eliminator axle,durablue posi loc axle nut,White bro's white power shocks with adjustable res's all the way around,Ac stadium series front bumper with # plate,Renthal trx250r bedn handlebars,PEP easy pull clutch perch and lever,909 grips,fastline braided steel brake lines,braking brake pads,uni filter,motion pro clutch cable,pro design kill switch,18/11/8 holeshot mx's on mithcell .190's,21/7/10 holeshots on ITP .190's
Old Mar 19, 2001 | 12:05 AM
DIEhardRlDER's Avatar
Check the bearings and back end. Make sure there is not to much play. Axles ,carrier and everything add up real quick. I found out the hard way on my 250x. Negotiate every little imperfection in the price.
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
Traci Carnahan Simmons
Aug 9, 2015 03:00 PM
CRamshaw777
Jul 18, 2015 05:46 PM
