disappointing
Old May 23, 2012 | 05:32 PM
95wolv's Avatar
Did you check the crank and rod for any slop before putting the piston in? if the rod has any play, or the crank bearing is worn, it will slap that piston around the cylinder as it flops around. Sounds like clearance problems, especially with the back side of the piston taking the damage, like there is slop in the power train allowing the piston/rod/crank to float to the back under the power stroke.
Old May 23, 2012 | 07:10 PM
6jeff6's Avatar
Everytime i bought the piston and rings from the shop that bored or honed it(same shop everytime). The last time i took crank and whole bottom end with rod and they said all were well within spec. Is there a shop that's good? How hard is it to spec the crank? The last time i helped put it together and everything seemed real tight but heck everytime did..
MikeyBoyesq
Nov 27, 2020 02:44 PM
j.graul84
1) Engine problems..
Nov 6, 2015 08:42 AM
Bernhard
Sep 25, 2015 12:45 PM
Yamadude1031
Where to Ride
Jul 16, 2015 02:13 PM
Area51
Aug 26, 2001 02:09 AM
