my 2003 400ex wont start please help
Old Sep 29, 2012 | 11:55 AM
jerseyrider856's Avatar
Default my 2003 400ex wont start please help
My 400ex will not startup it will crank but wont turn over i adjusted the valves check the timing put a new sparkplug and battery in it put fresh gas in it i dont know wat else to do to it
Old Sep 29, 2012 | 12:12 PM
Knust's Avatar
Did it run before you did all that? If so maybe the valves are too tight causing low compression.
Old Sep 29, 2012 | 12:27 PM
yea i had it in storage for bout a year and a half but i brought it from my cousin he said he was riding n it jus cut off on him while he was riding so i brought it n had it in storage
Old Sep 29, 2012 | 12:35 PM
i did another valve adjustment yesterday
Old Sep 29, 2012 | 01:21 PM
Knust's Avatar
Do you have spark?
Old Sep 29, 2012 | 01:23 PM
Knust's Avatar
If so try a little either in the carb if it fires fuel is your promlem
Old Sep 29, 2012 | 01:28 PM
Yea i got spark pulled the plug and put it next to the frame but after i held it in my hand first lol n i put new gas in it
Old Sep 29, 2012 | 01:32 PM
Knust's Avatar
Did the carb have fuel in it during storage if so that carb needs to be cleaned very well
Old Sep 29, 2012 | 01:37 PM
Yea wat should i use to clean it
Old Sep 29, 2012 | 01:58 PM
Knust's Avatar
take it apart use carb cleaner and compressed air to clean passages and jets very good. Make sure everything is clean a grain of sand can stop up the jets.
