2003 400ex not firing?
Old Oct 21, 2012 | 04:11 PM
chad21000's Avatar
Default 2003 400ex not firing?
I have a 2003 400ex and its not firing, replaced the stator (its a 200w ricky stator if that makes a differnce),wiring harness,button pad (where the startbutton/killswitch/lights), cdi box, and even the coil. Just dont know whats wrong with it.
Old Oct 21, 2012 | 06:02 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Have you checked the voltage regulator? Give alittle history on this atv//Was it running then quit? Did you just traded for it an wasnt running? Was it running before replaced stator?
Old Oct 22, 2012 | 02:20 PM
chad21000's Avatar
It broke,then he bought all of the stuff i listed , hes had it since it was new. And i have no idea if he checked the voltage regulator, ill ask though.
Old Oct 25, 2012 | 03:02 PM
Supercup's Avatar
I had a lot of problems with my Banshee after I installed a Ricky Stator 200 W stator. I put the stock stator back in and all my troubles went away. It was robbing spark and causing the bike to run poorly and quit. I found that those 200w stators were made in China and were not well made.
If he has the stock stator, since he has already changed out most everything else I would put it back in as well.
Good luck.
Old Oct 25, 2012 | 05:16 PM
chad21000's Avatar
we think we found the problem, one of the people at duncan racing international said that the only thing it can be is the ground wire, but does anyone know where the ground wire is, we really wanna get this thing going.
Old Oct 25, 2012 | 07:54 PM
jgar's Avatar
Did you check the fuse by the battery?
Old Oct 26, 2012 | 10:00 PM
chad21000's Avatar
we tested all the wires that connect to the battery, and the fuses. Were pretty sure its the ground wire, would anyone happen to know where it is?
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
greg86hd
Sep 16, 2015 12:32 AM
Hw00d
Sep 10, 2015 08:53 AM
Elkaholic
Sep 6, 2015 02:44 PM
Jason An Stacy Jones
Utility ATVs
Sep 6, 2015 02:25 AM
