2006 Honda TRX300EX overflow problem
Old Nov 16, 2012 | 01:07 PM
BlasterMan29's Avatar
Unhappy 2006 Honda TRX300EX overflow problem
I have a 2006 Honda TRX300EX that is mostly stock. ATV wasn't running properly so i took the carb apart and when i put it back together the quad was running, however gas was pouring out of the overflow tube. When i would take the choke off it would die out. I know why the ATV wasn't starting and running cleanly now, but i don't know why the gas is coming out of the overflow. Did i do something wrong putting it back together or is it another issue? Thank you very much!
Old Nov 16, 2012 | 11:07 PM
Mandanglelow's Avatar
Check your float hight,needle valve might be stuck.
Old Nov 16, 2012 | 11:12 PM
Check your float hight,stuck float valve
Old Nov 21, 2012 | 02:24 PM
dbert's Avatar
I am having the same issue on my 2000 Rancher....broke down carb cleaned out real good. ATV now running fine but fuel pours out the overflow. I saw a couple of posts that said to check the float level....how do you do that? I replaced my float needle so the level may be the only thing left to check, just not sure how.
Old Nov 21, 2012 | 04:07 PM
Need to get the service book and look at it,the fuel is coming from somewhere ,just take your time, no quick fix good luck, Dave, Long Beach, CA.
Land_shark1
Jul 10, 2015 12:53 AM
DTroyer01
Jul 3, 2015 07:34 AM
'86 TRX125
Jun 6, 2015 07:43 PM
blaze_master
May 26, 2015 11:18 AM
lovinhonda
Jan 25, 2000 09:17 PM
