XR 400 cam only upgrade?
Old Mar 22, 2001 | 11:16 PM
2001REDTRX's Avatar
My question to you all is do you think that it would be ok to just add a XR 400 cam to my 400. all that I have for an upgrade is a full LRD exahust and a UNI Filter. Will it run wierd without haveing a port job and a higher compression piston, or will it run fine. thanks-
Eddie
Old Mar 23, 2001 | 12:22 AM
86atc250r's Avatar
It will run fine, just like an XR dirtbike....
It will slightly shift the power more up into the mid and upper mid..
Don't expect any big differences with only this change.
Old Mar 23, 2001 | 02:17 AM
LDJ's Avatar
LDJ
While your in the engine I would put in a 10:5:1 piston or a 11:1. With these two combos it will feel like a completely different bike. The 400EX works well on higher compression piston.
Jmuddin284
Jan 19, 2026 07:16 AM
jankerstien
Sep 21, 2015 03:09 AM
Bonzhonda300ex
Sep 17, 2015 10:44 AM
Brandon400
Sep 5, 2015 08:44 PM
XxS0ccerstarxX
Aug 27, 2015 02:31 PM
