2001 Ruby TRX500FA
Old Dec 22, 2012 | 03:53 PM
Woot's Avatar
I got the driven gear hub off and the front ball bearing has pretty good slop like I said plus the wobble plate bearing does the same thing. I figure with both these bearings not tight, I'm losing pump piston travel and displacement which is power. I hooked up a 1" rubber hose to the trans input shaft and a 5/8" socket which I attached a 1/2" impact gun and put the trans in fwd and rev to see if anything internal was slipping and it seems solid moving both ways no problem.
I hope the squeaking noise was the two bearings....hate to get it back together and find out the aft bearing on the hondamatic trans is shot...Duh
Might jack it up and do the impact wrench gig with the wheels off the ground....see if I got any noise as the wheels will spin free..
Look what I found online:
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
35dodge
Sep 29, 2015 09:40 AM
jsmit116
Sep 18, 2015 10:34 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
chewy78
Sep 8, 2015 10:37 AM
