440ex engine noise
Old Aug 21, 2013 | 03:01 PM
Jumanji's Avatar
Default 440ex engine noise
got a noise coming from my motor sounds like the valves but there is what looks to be grease that has leaked out of 2 allen screws on the top part of the motor where the camshaft would be not sure what they are for though.
Old Aug 27, 2013 | 08:43 PM
the_revern's Avatar
The 440kit blows head gaskets like crazy. Depending on the noise and compression the head bolts could be stripped or I've even seen the cam bearing bolts work loose.
Old Aug 30, 2013 | 09:03 PM
Jumanji's Avatar
yeah ive heard of the head gasket problem. but ive got a link to a vid of the engine noise if you would check it out and let me know.
440ex engine sounds - YouTube
theres the link
Old Aug 30, 2013 | 09:19 PM
the_revern's Avatar
Definatly sounds like the valves or the rocker. I would say a simple valve adjustment and ur good to go. By the way. If you remove your head and steel helicoil where the head bolts go you shouldn't have to worry about the head gasket. I think its a 12mm od by 8mm I'd helicoil. Really easy to do. Just drill straight
greg74
Sep 10, 2019 03:03 PM
ronnierhino06
Nov 9, 2015 12:56 PM
hondarider1234
Jul 21, 2015 11:53 PM
ghost civic
Jul 19, 2015 10:13 AM
D-Hagz
Jul 4, 2015 02:19 AM
