help 81/82 honda 250r 3wheeler
hi im having an issue i just got this honda 250r it starts up 1st or second kick idles but once i pull the clutch put it in gear it jerks a bit n shuts off , (didnt even start releaseing the cluch at that point )
i got a second engine with that bike is in pieces but it is complete.
i can post video just need to figure out how to upload it from my phone to the site
iv been dieing to ride it iv been wanting one of these since i first started riding 3wheels
i took the clutch cover off and proceed to remove the bolts and springs got them off and noticed the plates were sticky so i swaped the plates and everything for the spare one i have but when i press and release the cluch it doesnt seem to move . is the push rod soppose to push the basket lid off and when u release it , it close's is this correct or am i wrong
Check photo #22 is ball in front push rod..this could be missing...When you press clutch lever it should lift the clutch plate off of basket so trans will shift then when release lever lift plate should make contact with clutch disc an starts pulling..If ball is gone this will make stroke to short an wont lift plate off of the disc..This is real easy to loose for me if not careful when pulling push rod out.
Alex Rodak
09-13-2015 12:30 AM
Alex Rodak
09-12-2015 09:39 AM
Alex Rodak
09-11-2015 11:42 PM
