2004 400ex starting problems
Old Mar 9, 2014 | 02:37 PM
440BigBore479's Avatar
Default 2004 400ex starting problems
I have a 400ex with a 440 big bore kit and stage two hot cams with a full dg exhaust and a eddelebrock carb series doug E. I got it for 750 bucks but cant seem to get it started. When I spray starting fluid it starts occasionally then immediately dies. Haven't changed the spark plugg yet but surely that be my full problem. I was thinking that the carb needs adjusted bit I can't find any specs for tuning any where online.
Old Mar 9, 2014 | 04:23 PM
sdm24's Avatar
here is a good place for honda sports quad jetting info.
Sport Quad Carb Jetting (stickie maybe) - Honda ATV Forum
I think you should change the spark plug. If nothing else take out the one in there and see if you are rich or lean
Old Mar 9, 2014 | 04:52 PM
How do you tell by looking at the spark plugg? Thanks
Old Mar 9, 2014 | 07:35 PM
sdm24's Avatar
Spark Plug Chops and Jetting
here is a website that shows pictures of what I am talking about. Basically the spark plug should be a tan color. If it is white you are running too lean and you know you need more fuel. If the plug is black you are getting to much fuel. It is a good starting point.
Old Mar 12, 2014 | 08:51 PM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
If he can't get it started, he can't do a plug chop.
Sounds to me like a fuel delivery problem.
Old Mar 26, 2014 | 07:28 PM
FarmLifeMS's Avatar
Will it turn over? Usually, it will crank and sputter if the carb needs adjusting. Try holding the throttle slightly and then trying to crank.
Old Mar 27, 2014 | 06:29 AM
sdm24's Avatar
I think you misunderstood what I was saying. I said if it isn't starting the first thing he should do is check the plug. He asked how to tell the difference between a lean running and rich running condition. I found a website that had pics of plug chops with different running conditions. I was not suggesting he did a plug chop on a bike that isn't running. Sorry for the confusion.
neilbedwell
Nov 10, 2018 11:02 AM
Land_shark1
Jul 10, 2015 12:53 AM
DTroyer01
Jul 3, 2015 07:34 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
