1986 honda trx 350 4x4 fuel pump problems
This is where I'm at right now.
I have already installed a new fuel pump, and a fuel cut relay module, but still cant get power to the fuel pump.
I can connect the fuel pump directly to a 12 volt battery, and it works fine, fills the carb with gas, and the motor starts right up and runs great until it
uses all the gas out of the carb.
I cant figure out why there's no power to the fuel pump???
If anyone has any suggestions, or answers I would appreciate it.
The CDI box sends signal to fuel relay may have an bad CDI on that leg. just get wiring breakdown an check the wire that sends signal to relay from CDI.Jusr remember starter button has to be pushed in to send signal to CDI since this system work off of ignition pulse
