help honda atc200 1981 kit carburetor
Old 04-19-2014, 06:45 PM
ginooo1989's Avatar
Default help honda atc200 1981 kit carburetor
i bought a new kit for my carburetor pd 35c for my honda atc 200 1981 that came with 2 main jet numbers 95 and 100 and 2 throttle needle 1 is d71 i don't know the number for the other one which main jet and throttle needle is the right one to use also did i get the right kit
Old 04-19-2014, 07:22 PM
Used these kits in the past and not always spot on for early model machines. Your model shows a 105 main jet as stock,but the 100 shouldn't be that far off. As far as the needle,just shows a needle kit on the parts breakdown. Just try one and see how it does. You can always pull it out and try the other one if need be. Dirt Cheap Honda & Arctic Cat OEM Parts & Accessories – Cycle Parts Outlet
Old 04-19-2014, 09:09 PM
ginooo1989's Avatar
ok thanks
Bonzhonda300ex
09-17-2015 10:44 AM
bigred20653
08-31-2015 12:41 PM
08-18-2015 01:00 AM
willday08111217@gmail.com
Technical and How-To Articles
08-01-2015 04:05 AM
Quick Reply: help honda atc200 1981 kit carburetor
