1984 Honda Big Red ATC200ES
Old Apr 24, 2014 | 06:44 PM
BushPilot87's Avatar
Default 1984 Honda Big Red ATC200ES
First post, here we go!
Recently acquired an 84 ATC200ES, and having an electrical issue of sorts.
Currently no battery in the bike, but when I pull the cord there's spark on the first haul and none on the second or third. If I wait 5 secs or so, the same thing happens again, spark on first pull and not after.
I have pretty much ruled out a bad ground (cleaned all ground points, jumper cable from neg terminal on battery to plug, and no difference).
Any ideas before I start hauling the trike apart?
Old Apr 25, 2014 | 01:54 AM
Check the pulse coil on the end of the cam. I had a stator coil go bad on an ES but while checking things had changed the pulse coil. When fitted with a new stator coil it was sparking iregularly and I had to get the distance from pulse coil to magnet down a bit to get it to work properly.
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
rgjackson
Sep 17, 2015 11:21 AM
wendal
Sep 15, 2015 01:50 PM
Jason Campbell
Sep 7, 2015 02:25 PM
