big red 250es
Old Nov 24, 2014 | 01:17 PM
Chandlerksymonds's Avatar
Default big red 250es
My big red 250es has bad piston rings so it smokes but more recently it started to sputter a lot and have a real hard time idling, It may be water in the gas i am not sure because it just started happening as it gets warmed up or im riding fast for a while then as i start to slow down it would go away, Now its constant it always wants to die and sputter even after a cold start. Could it be the piston rings?
Old Nov 25, 2014 | 02:44 AM
Change the plug, it will be having a hard time in an engine burning oil, this may cure the symptoms for a while but they will return. I guess compression may have got so low that the machine won't run right but I think bad starting and poor running at low revs would be more likely. If a plug change doesn't work, why not try cleaning the carb out? If there is water present, more may be in the tank, but most likely some grit will have got into the jets.
Wooodyii2
Nov 16, 2020 07:14 PM
dwardfa
Aug 19, 2014 04:29 PM
tparsons
ATC 3-Wheelers
Jun 22, 2007 10:09 PM
