HRC cam update
I had a used WebCam all-around grind before I got the HRC. I bought it used from East Coast ATV for $60. It was a waste of money because it was worn to the point that I didn't feel right putting it in. I thought I might send it back to WebCam to cover a core charge and get a new one, but they wouldn't take it back. Anyways, I wasn't very happy to lose the decompression feature like you do on all the WebCams. Also, I wanted to keep my stock cam just in case someday I want to put it back to stock. Performance-wise I decided that I wanted something hotter than an all-around grind- since I do a lot of dune riding. With the HRC cam I hope to find performance between a race cam and an all-around cam. Cost-wise, the $270 for the cam isn't bad if you figure that you're keeping your stock cam. Also, you don't have to get the hardened rockers- that saves a ton of money.
Before you put the FCR carb on you bike, what jetting did you have for the stock carb? I'm curious because I just did similar stuff to mine and haven't got the jetting perfect yet. Did you have to change your pilot jet?
#15
I don't have to run race gas, it runs fine on premium pump gas. The costs were as follows: piston, rings, pin $140, gaskets $25, bore job $45, cam $280, optional hardened rocker arms $240.
Since then I have found a cheap place to get a JE piston. www.motorcycle-atv-pwc.com sell the 416 JE piston for $155.95- that price includes the piston, AND the cost of boring and return shipping! $156 (piston/bore) + $25(gaskets) + $280 (cam) = $461. For about the same price as a full pipe you can get a piston/cam package that will do a heck of a lot more for you than just the pipe would.
#16
Has anyone done business with this place (Wholesale Parts & Accessories)? They use Marcum's ATV in Palatka, FL. Has anyone had work done at this shop? If so, did they do a good job on the their engine work? Please help if you can.
Axl_Z
Mar 9, 2025 11:14 PM
ModdedX
Jan 23, 2001 09:56 PM
