2005Honda rancher 400 AT
Old Apr 14, 2016 | 05:57 PM
steve1747's Avatar
Default 2005Honda rancher 400 AT
I have a 2005 Honda RANCHER 400 AUTOMATIC WITH N500 MILES. DUE TO A SERIOUS INJURY, I HAVE LEFT THIS BIKE IN MY (HEATED) GARAGE FOR NEARLY 3 YEARS. I JUST BOUGHT A NEW BATTERY, DRAINED AND REPLACED THE GAS, AND INSTALLED A NEW PLUG. STILL WON'T START. ANY IDEAS?
Old Apr 14, 2016 | 08:59 PM
papatrk's Avatar
Hi steve1747. I'm new to this site as well. Can you give a bit more information as to what is going on? I also have a 05 Rancher TRX400. Some specifics like is it turning over? Are you getting any spark? Does it sound like it is going to start, but just never quite gets there? The more specific you can be the better.
Old Apr 15, 2016 | 06:45 AM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums.
Check out the Honda section, you'll get far more replies over there and they should have you running in no time.
Old Apr 16, 2016 | 01:39 AM
It could be a valve stuck after all this time, or the cab jets bunged up. I usually start by pouring about 20cc of fuel directly on the air filter, if the bike then tries to start, you probably have a carb problem. I have known this technique to be a cure in itself. I think the suction caused by a running engine may clean jets out. Anyway, if you don't get any sign of "life," check for a spark, if you have one, check compression.
chazdo277
Apr 14, 2016 04:06 PM
GeraldB
3) General Discussions..
Apr 12, 2016 09:18 AM
jvillads
Apr 10, 2016 09:21 AM
Mark Bailey
Utility ATVs
Mar 27, 2016 09:53 PM
