2004 Honda 250ex
Old Jun 18, 2018 | 08:45 PM
Kyle Thompson's Avatar
Default 2004 Honda 250ex
Hi all I'm new here I just got a 2004 250ex and just got it all up and running good after someone butchered the wiring harness I thought that was bad now reverse neutral and all 4 gears work and shift great until I get into fifth makes a grinding noise acts like it wants to go then grinds I don't think the gear is stripped no sign of metal in the oil has anyone ever ran into this problem before could it be so.ething simple under the clutch cover any help on this is greatly appreciated
Old Jun 19, 2018 | 01:41 AM
Only work on Recons but it is the same basic engine, and they do strip top gear. Usually there is no grinding, just an extra neutral where 5th should be.
Old Jun 19, 2018 | 06:35 AM
Would there be metal in the oil if the gear was stripped
Old Jun 19, 2018 | 06:37 AM
Default 250ex
Wouldn't there be metal in the oil if the gear has stripped or some sign
Old Jun 20, 2018 | 01:33 AM
Didn't see any. Can't remember what I found on stripping, but it was a few big bits that had broken off, nothing small enough to get through the mesh screen where the drain plug is.
Old Jun 20, 2018 | 08:38 AM
Thank you for the reply this just sucks I think the people tore the wiring apart to mask the fact that it had no fifth gear I've never had a transmission apart before
pugads650
Aug 9, 2008 06:14 PM
ohiofirelt
Oct 2, 2005 12:25 AM
gcextreme
Apr 8, 2005 02:43 AM
mickeymouse8u
Jul 3, 2004 06:08 PM
