TRX 90 Electrical problem
Old May 11, 2019 | 03:18 PM
mauser22's Avatar
Default TRX 90 Electrical problem
2016 TRX 90 Neutral light does not come on in neutral It comes on when You turn the kill switch but will not let You start it. Thanks in Advance Gary
Old Mar 4, 2021 | 12:40 PM
Francois Boule's Avatar
Same issue here, the trx 90 is in neutral but the green light won’t come on, so I can’t start it. Any idea where is the problem?
Old Mar 5, 2021 | 02:23 AM
I only have the book for the earlier, pull start model, so no wiring diagram but assuming it follows the usual Honda idea, wire goes from neutral switch to light and to solenoid green wire, often via a diode. When you change gear into neutral, the switch earths this wire, putting light on and providing earth side of solenoid, starter button provides positive feed for starter solenoid thin wires.
honda 77
Aug 22, 2013 06:10 PM
yztim
Mar 23, 2008 04:24 PM
