axle bearings
Old Apr 25, 2001 | 06:28 PM
400exalltheway's Avatar
i just wanted to know if there was any trick to taking out the axle bearings before i start. thanks
Old Apr 25, 2001 | 09:00 PM
coryatver's Avatar
I am also about to change my bearings.... any tips?
Old Apr 26, 2001 | 09:12 AM
dhines's Avatar
Hey guys,
I had a major problem getting the bearings out of the axel carrier the first time I tried it. I tried for hours until someone gave me some very simple but effective advice. All you have to do is take the carrier and turn it on its end and then smack it down on a piece of wood. A couple of good whacks and the bearings will slide on out.
If it is still a little tough you can use a torch and heat up the carrier a little to loosen things up.
Regards,
Dennis
Old Apr 26, 2001 | 12:33 PM
CP's Avatar
CP
You could also try using a drift to knock out the bearings.
Old Apr 27, 2001 | 12:52 AM
RotGutBottom's Avatar
Do you have to grease the bearings as a maintenence thing? How often?... has anyone done this?
Old Apr 30, 2001 | 06:19 PM
the replacement honda bearings i got were sealed with greese so you won't have to, i'm not sure about aftermarket bearing though
wendal
Aug 3, 2024 10:03 PM
exmotocrosser
Sep 13, 2019 06:12 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
jbrewster94
Sep 23, 2015 04:16 PM
1000gade
Sep 9, 2015 04:41 PM
