Winch Cant Get Wet?!
Old May 14, 2001 | 10:51 PM
Rancher4x4ESLuvr's Avatar
Whats up with this.. I read my Warn 2000lb winch manual and it says it cant get wet.. How can this be? Why would everybody have winches if it cant get wet? Can someone please let me know if it is just there for legal reasons? Like my rancher can only cross 10 inch streams, lol yeah right.. Thanks!
Old May 14, 2001 | 11:46 PM
JKB's Avatar
JKB
I have the same winch and read the same thing. At first I was concerned but after a year of using it totally submerged and pulling out the bike, it no longer bothers me. I had heard someone else mention that it would be a good idea to clean and lube it once a year in case water was getting in. I can tell you that it will work under water {Thank $&$@ !}
Cheers Jim
Old May 15, 2001 | 07:52 AM
kindsambo's Avatar
I have a Warn 2500 and if the $%^&*@# thing even thinks it's wet it won't work. It was installed by the dealer and I think they must have botched up the install bigtime. Going to rewire and seal all the connections and hope for the best. The damn thing won't work if it's raining!!!! ARRRGGGGG!!! Superwinch is looking real good to me now and at half the cost.
Anyone else have a problem like this with their Warn?
Old May 15, 2001 | 02:32 PM
Wow that really stinks about the 2500.. Im thinking something is wrong with the installation after reading the first post! =]
Old May 15, 2001 | 09:10 PM
bdsomers's Avatar
I have a 2500 on my rubicon and every weekend my quad get buried in mud and water and that winch works every time. It even runs when completely submerged. As long as all your connections are done properly you should have no problems.
Old May 16, 2001 | 11:43 AM
bigsqueeze's Avatar
I know the instructions say not to get the Warn wet. Mine has been wet, .. very wet as a matter of fact and it's always worked.
I'm careful afterwards to pressure wash the winch and cable and then spray the whole thing down with WD-40. (Works after pressure washing too.)
Anything less and I'd trouble-shoot your electrical wiring until it did work.
I'm prepared to coat the electrical connections with waterproof lube if mine ever fails to work.
Old May 17, 2001 | 05:20 PM
1BadRat's Avatar
I too have a Warn 2000 and it has been totally submerged many, many times, and have never had a problem! Happy trails.
Old May 18, 2001 | 12:37 AM
Rubidude's Avatar
You'll probably find that little disclaimer somewhere in every manufacturers owners manual. It gives them an "out" on the warranty coverage if they can show that your ATV was in wet conditions.
Old May 18, 2001 | 10:17 AM
TEXMud's Avatar
Rancher4x4ESLuvr, yes it can get wet. Mine gets wet on every ride.
Rubidude, That little disclaimer has recently bit a friend of mine who sank his quad. He thought if he cleaned it up well they would never know. I told him they would.....well they did. The two easiest ways are to check the seat for water and check the battery compartment for sand or mud.
Johnny Mac
Aug 15, 2019 03:13 PM
salixair
Nov 3, 2015 08:25 AM
cboler9
Sep 24, 2015 08:35 PM
ylomnstr
Sep 10, 2015 06:45 AM
chewy78
Sep 8, 2015 10:37 AM
