FOUL PLUG ON 250R
Old May 16, 2001 | 01:22 AM
gottooride's Avatar
I've got a 88 250r that fouls a plug if i'm riding in tight woods or if I hold it wide open. Do I need to rebuild the top end or what?
Old May 16, 2001 | 11:29 AM
retro's Avatar
Is your airfilter clean? You need to rejet.
ERIC
Old May 16, 2001 | 05:19 PM
springdrl's Avatar
An engine that fouls plugs so often should have a very rough or uneven idle if the problem is too rich a mixture. It could be jets or worn 0-rings within the carb. If this a 4-stroke, look for black smoke when you rev the engine. There should be none at all.
Old May 16, 2001 | 11:18 PM
gpds650's Avatar
i got the same problem,after about 2 gas tank got to change the plug,the plug is brown do.a good think plug are cheap.Can wait for the end of this month im bringing my motor to Duncan to get a complete engine rebuild.i havent deside what kit im going to get, any suggestion would be appreciated.
Hankey Pankey
May 1, 2018 01:33 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
cornermike
Jul 30, 2015 06:37 AM
Captjay
Jul 23, 2015 12:33 PM
CRamshaw777
Jul 18, 2015 05:46 PM
