squeeky 400ex
Old May 26, 2001 | 02:08 PM
MiStA400EX's Avatar
i was just wondering if anyones 400ex squeeks from where the axle goes through the swing arm? mine does this every now and then and it is very annoying. any help would be great. thanks
Chris
2001 400ex
DG Pro Peg nerfs
Old May 26, 2001 | 04:01 PM
danyeo's Avatar
I have had lots of squeeks on my 400ex all over and there was nothing that WD-40 didn't take care of. But i never had noise coming from the area you describe.
Old May 26, 2001 | 09:19 PM
Need4Speed's Avatar
It wouldnt hurt to take the axle off and grease the bearings, i bought a bearing carrier that had a grease zerk on the outside and i grease it every time i wash my quad. Works like a charm.
Old May 26, 2001 | 11:33 PM
Buckeye400EX's Avatar
Need4Speed, Where did you get the bearing carrier with the grease zerk? And how much was it? Thanks!
Old May 27, 2001 | 02:04 AM
MiStA400EX's Avatar
ok i will have to do that, one question though, how do you get the axle off. i mean i know you have to take off the brake caliper, the chain, but i dont understand which way to turn the two locking nuts? any help would be great.
thanks,
Chris
Old May 27, 2001 | 01:31 PM
Need4Speed's Avatar
I bought the RAD dual row bearing carrier. I saw their add in Dirtwheels and bought it from them. It ran around $180, I think, but that was for my 250X. Their #is 877-277-1112
Old May 28, 2001 | 09:32 AM
Need4Speed's Avatar
The locking nuts are a pain in the a$$ if you ask me. The nut is left hand thread and getting it off might give you hours of cursing, screaming, hair pulling, and fustration. Mine when I took it off was froze up so I had to heat it up to get it off. My advice to you is once you get it off do yourself a favor and thorw it in the trash can. I bought a durablue axle locknut. For $50.00 it was by far one of the best things I ever did to my quad.
Old May 28, 2001 | 10:52 PM
MiStA400EX's Avatar
does the 400ex have a master-link? that sounds really dumb, but i looked for about 30 minutes and could not find it. i also had my dad look too and he couldnt find it, and yes i do know what a master link looks like. its just not there we looked on both sides the chain and no luck. i have been riding it too for the past 3 weeks and the chain has not came off so i dont know how its on there. any help?
Thanks,
Chris
Old May 29, 2001 | 10:08 AM
MIA416EX's Avatar
My 400EX has always had the same intermittant "squeaky" axle since I bought it...
The guys I had look at it said it is the seals rubbing the axle...not the bearings themselves. Therefore there should be no problems, however, if its squeaking, its heating up, and therefore the seals MAY wear faster. Just keep an eye on it, and if you do a lot of riding thru water, loosen the 4 axle bolts (like you are adjusting the chain) from time to time....I have noticed that the axle housing WILL hold a small amount of water, and loosening the bolts will let it out.
I don't think the 400EX has a master link. You just need to slack up the chain adjuster, and pop off the chain...
Old May 30, 2001 | 05:23 PM
MiStA400EX's Avatar
how can the 400 not have a master link? hwo do you get the chain off? that would be a real pain to have to knock one of those pins out. any help thanks, chris
