rubicon carb air vent hoses?
Old May 28, 2001 | 12:50 AM
goattrotter's Avatar
Has anyone ever run the carb air vent hoses up higher to keep water from getting in to carb?Is there any reason why this should not be done?Thanks.
Old May 28, 2001 | 01:41 AM
TEXMud's Avatar
Yes and yes. I have rum mine up the side of my snorkel. Basically in order for the carb to work properly it needs atmospheric pressure. Underwater it can not get this. It will also not get this if run into the airbox or into the snorkel.
Old May 28, 2001 | 12:05 PM
Thanks,I guess it would explain why it started to die and then I had water in the carb but not a drop in the air box so the water must be entering threw those vents.
Mark
Old May 28, 2001 | 05:15 PM
TEXMud's Avatar
If you are getting in water that deep then yes you will have problems. Water in the carb bowl will be to the carb drain line though. You need to plug it when you ride in water. Use a screw or a stick to plug it up.
Old May 28, 2001 | 08:54 PM
Why does it go in threw the drain hose?Does that check valve not stop the water from going all the way up there?Does pluging it cause any other problems?Thanks Texmud.
Old May 28, 2001 | 09:21 PM
Is there any other tips you can pass on to make sure it does not stall when going threw deep water,any help is always greatly appreciated.
Old May 29, 2001 | 12:02 AM
TEXMud's Avatar
The 1-way valve lasted me about a month on both my quads. After that they started to die. Plugging the carb drain the only thing you need to worry about is turning off the gas when you transport it. This will keep you from getting gas in the airbox. I would highly advise ANYONE to move all vent lines as high as possible. On a Rubicon this includes the coolant overflow vent line in the rear (lowest on quad).
Old May 29, 2001 | 12:38 AM
Thanks for all the advice,I know what I will doing tomorrow,I really over looked the coolant reservoir tank.
Old May 30, 2001 | 11:28 AM
How do you check the check valve?Do you just blow in it to see if it will let air past it? Thanks[img]i/expressions/face-icon-small-smile.gif[/img]
SDR-II
Sep 29, 2015 01:06 AM
Captjay
Jul 23, 2015 12:33 PM
ghost civic
Jul 20, 2015 12:36 PM
Unzzy66
Jul 11, 2015 10:01 PM
