Rubicon in 2001 Silverado Short Bed
Old May 28, 2001 | 10:27 PM
marcopolo's Avatar
I have a Rubicon with its original tires and it "just" fits in my truck with tailgate closed. If I put 26" or 27" on my Rubi will my tailgate close??
Are there any Rubi and Silverado owners with biggers tires out there???
Thanks
Marco Polo
Old May 29, 2001 | 05:27 AM
Stomper's Avatar
marcopolo,
Which way do you put your Ruby in your truck, drive it in or back it in. I drive mine in and I'm about 3 or 4 inches short of shutting the tailgate. Unless you put the rack right up on the rear window of the truck (which I won't do)it won't fit.
Old May 29, 2001 | 01:27 PM
marcopolo's Avatar
I drive it in and the tailgate closes if I "force" it close. The rack is about 3-4 inches from the window.
What kind of tires do you have???
Old May 29, 2001 | 04:31 PM
dakotart's Avatar
Before I bought my trailer for my Arctic Cat 500 and 400 I had the same problem with my Dakota R/T. An easy solution is to buy a portable air tank and let the air out of the tires to around 1-2 psi so the gate will close. Air up the tires when you arive and you are set. It is also nice to have in case of a flat or to dust off an area if needed. It worked for me until I bought an extra quad. It should work just fine with the larger tires.
Dakota R/T
Old May 29, 2001 | 04:36 PM
TEXMud's Avatar
Be very carefull forcing the gate shut. I eventually damaged my locking mechanism doing that.
Old May 29, 2001 | 06:26 PM
up2snuf's Avatar
I can close the tailgate on my old swb Silverado with my stock Rubicon loaded. Before I close it, I drive the Ruby's front wheels up on a couple of 2X6 boards that are about a foot long each. This extra height on the front allows it to go in a tad farther. Then I put a couple of tie-downs from the rear stake holes to the foot pegs since there's only a couple of inches clearance behind the rear window.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
35dodge
Sep 29, 2015 09:40 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
black_thunder
Sep 22, 2015 07:59 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
