Go to a 14 tooth or not
I'm assuming that 15 tooth is stock on a 300ex (just like a 400ex)...
By dropping teeth on the front sprocket- you will LOOSE top end- and gain bottom end. You'll notice more power on hill climbs and a little faster acceleration.
Also- if you ever put bigger tires on your rear- you will need to drop to a 13 tooth. The bigger tires will cancel out the low end gain you made with the 14 tooth.
...actually- you may want to even go to a 13 tooth now. If you think about it- how often do you ride in 4th and 5th gear? You really don't hit those gears. Most riding is done between 1-3rd. So with a 13t sprocket- you'll get alot of low end power!
i put a 14t on mine. the only difference i saw was a small increase in top end and it does not seem to whine out so fast in first gear. great mod for $20. you HAVE to remove the case saver. i just left mine out becasue i have not had the time to grind it down. if i were you, i would fix the case saver asap.
NT
NT
I put the 14 tooth sprocket on my '98 300EX that has a full White Bros. header/pipe, jet kit, K&N air filter, modified air box lid, the rev limiter removed from the CDI, and 22inch Holeshot XCT tires in the rear.
Now, I'm about 4 bike lengths behind my buddy with a modified 400EX at top speed (just pipe, jet kit, air box lid) whereas before I was about 12/14 bikes lengths behind him. In a drag race he doesn't pull away from me until I almost hit four gear. The rev limiter is also very restrictive on a 300EX, so my last two mods were the 14 tooth and CDI box -- they both made a big difference!!! I would say the 14 tooth is good for about 5 to 8 MPH on top end.
You do have to dump the case saver and you do lose a little off the bottom end (I noticed it is a little harder to start off from a stop in second gear), but otherwise well worth it!
-Heavy J
http://atving.freeservers.com/
-Heavy J
