adjusting valves
Old Aug 11, 2001 | 06:00 PM
curt234's Avatar
How important is it to adjust the vavles. I notice on my fourman it makes a little tickying sound after I rev in out to get out of a mud hole.
Old Aug 12, 2001 | 12:17 AM
gutairjunke's Avatar
How many hours have u rode it?
Old Aug 12, 2001 | 12:53 AM
curt234's Avatar
88 hours
Old Aug 12, 2001 | 03:37 PM
springdrl's Avatar
Unless you're having problems with the engine starting, I wouldn't worry about it. Valves will often get a little noisy once they heat up and the tapping clearances begin to expand. You might even rest at ease knowing the valves might be a little loose since they will not burn around their seats like those that are too tight.
I check mine no more than once a year.
Old Aug 14, 2001 | 01:31 AM
honda205X's Avatar
as long as it starts up fine...cold starts that is..., and doesn't cut out once you get goin, the valves don't need adjusted.
it could also be low oil level causing the valves to make that "tapping" sound that your hearing.
you only need to check valves on a stock engine once a year at the most.
Old Aug 14, 2001 | 10:45 AM
Riceburnin's Avatar
I would say only adjusted valves once a year is not enough. Performance, reliability, and the noise of the valves are all reasons why they should be adjusted. Most people think it is hard to adjust them so they just dont do it. On most quads it shouldn't take longer than an hour or two to do.
Old Aug 14, 2001 | 11:26 AM
Raptoryfn660r's Avatar
RIP Dear Friend
I never have adjusted the valves on my Recon and it has 330 hrs on it. It always starts and runs fine. Chet
Old Aug 14, 2001 | 04:21 PM
curt234's Avatar
How do I adjust the idle so it is a little higher and more smooth. I know you can raise the slide but do you also have to adjust the Fuel jet or piolet jet or something like that. Also I had a older bike that I adjusted the valves on and it starts o.k but the tapping sound is really loud. Valve clearents to loose?
Old Aug 14, 2001 | 05:24 PM
AdamPhillips's Avatar
look at ur carb, there should be a little black *** on it. i think its on the right side but i dont know bout foremans. turn it in till u think it sounds right. do it when its runnin.
Old Aug 14, 2001 | 07:02 PM
pooh's Avatar
adjust the valves,per manual then after warranty is gone do what you want.
freeman34
Jan 8, 2016 11:46 AM
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Brandon400
Sep 5, 2015 08:44 PM
Jason Richards
Sep 4, 2015 06:17 PM
