To anyone with a ATC110 Service Manual.
Old Sep 5, 2001 | 07:46 PM
250rampage2's Avatar
Could someone tell me, or give me a website that has the Specs for the valve and points clearance for an ATC110? Thanks alot.
Old Sep 5, 2001 | 08:00 PM
Woodo68's Avatar
I have a manual at home and can post a scan of the pages you need. Give me a day or two if no one else helps.
Check out www.3wheeler.org try the message board you may have some luck.
Woodo
Old Sep 5, 2001 | 09:29 PM
Thanks a ton, my e-mail address is zurc@wilkshire.net
Old Sep 6, 2001 | 08:12 PM
momar's Avatar
I have a Clymer service manual and it says the valve clearance for both valves on a 1980 110 is .07mm or .005in. on a cold engine. The point gap is 0.3-0.4mm or 0.012-0.016 in. at the maximum opening.To adjust the valves you need to remove the recoil starter and rotate the crankshaft counterclock wise until the piston is at top dead center on the compression stroke.The "T" mark on the alternator rotor should be aligned with the fixed pointer on either the crankcase or alternator assembly. If both valves are not loose rotate the crank 360 degrees until both valves are loose. Hope this works...It's from the book...GOOD LUCK.
Old Sep 6, 2001 | 09:00 PM
Thank you so much...
Old Mar 13, 2006 | 12:49 AM
tysonpyro's Avatar
Default To anyone with a ATC110 Service Manual.
I was woundering if anyone knows what kind of oil 2 use and oil capacity in the crankcase and the gearbox for my 81 atc 110. thanks[img]i/expressions/face-icon-small-confused.gif[/img]
Customer Service #1
May 15, 2020 08:46 AM
Specta
Family ATVing Photos
Dec 7, 2018 08:22 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
Elkaholic
Sep 6, 2015 02:44 PM
