Reeds ? for a 250R
ESR reedblocks are rather expensive, and you have to run a clamp on filter with them. I suggest the boyeson power reeds. And if your R is stock ported, you've just about got all the bottom end you need, anymore and you'll be spinning those 18" tires off the rims.
ESR has a reed cage setup that you can use your stock airbox with, it just doen't have the built in reed spacer for more velocity. I personally have run both the Duncan Pyramid valve and the V-Force setup and both units worked very well, i'd recommend either one.
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
