bike will idle but wont trottle up
Old Oct 26, 1999 | 01:53 AM
rick{nv}'s Avatar
what could the problem be i changed the plug{thaght it might be filed} like it ain't getting any gas? or to much gas/ it will run at idle with choke on an off it's a 1988 250 x honda do you have any ideas?
Old Oct 26, 1999 | 03:02 AM
hot_shoe_cv's Avatar
Rick,
I had a similar problem with an 89 Suzuki. It turned out to be a worn out carb. The slide & needle jet were worn down to the point they were not functioning. The alternative was to rebuild or replace the carb. Since it would have cost about the same amount $200, I traded it in on a new quad.
THE AZ HARD PACKER, calmiller@kachina.net
save the public land FOR you, not FROM you..join the Blue Ribbon Coalition online @ www.sharetrails.org
Old Oct 26, 1999 | 03:46 AM
JRM's Avatar
JRM
how long as the bike been sitting?, sounds like you have a cloged main jet..pull the bowl off the carb and clean the bigget jet with compressed air as wire will damage the spray pattern inside the jet..
Joe
Old Oct 26, 1999 | 11:22 AM
WAYMOD's Avatar
Sounds like the clip holding the needle in your carb is broken.
When this happens the bike will start and idle but will not rev up.
This is a common problem just replace the clip...
Waymod
Old Oct 26, 1999 | 07:35 PM
YamaHonda's Avatar
All the replies above are valid and it definitely sounds like you have a lean condition. You might also check for air leaks in the rubber boot from the cylinder to the carb. Do a visual inspection, if you don't see anything you can try spraying WD-40 around the boot and see if it idles any differently when sprayed. If so, you probably have a leak. This is how we check for intake manifold leaks on our jet-skis, but the idea should apply here as well.
Old Oct 27, 1999 | 05:42 AM
JRM's Avatar
JRM
I also thought about the intake air boot, but didnt post that because at idle is when there is the higest vacume, and full throttle would be lowest. This makes them run ok at full throttle and poor at idle as it only sucks around the boot when idleing..but still something to check out older machines can be a handful.. it even could be a bad ignition..seen that once, but id bet money it is in the main circuit.. Joe
Firefighter400
Oct 8, 2022 06:38 PM
slowgsxr97
Mar 18, 2022 03:40 AM
COFatboy
May 2, 2020 12:06 AM
ghost civic
Jul 27, 2015 03:15 AM
ranvette
Jul 12, 2015 06:34 AM
