What plow setup?
I want to get a plow for this upcoming winter but don't know what to get. Should I get a manual, electric, or winch lift? Moose, Cycle Coutry, or other brand? What size of plow? I will mostly be plowing driveways in my neighborhood. My machine is listed below. Thanks for any help.
I would get the electric lift, because the winch lift will shorten the life of your winch because of the constant use and the manual lift just plain sux I had one on my TRX350 and when I would hit a bump it would come up and slam me in the knee. The manual lift is also just a pain to keep lifting if you are going to be doing more then one driveway or a big driveway. I had a cycle country plow and it was awesome my TRX350 had enoguh power to push the 60inch plow but I had stock tires. I would say go with the 60inch plow because the TRX300 is geared real low and It should have more then enough power to push it.
PS in the deep snow or the sticky stuff you might wanna invest in some tires chains in the rear and put alittle weight in the back to offset the weight of the plow. Good Luck, Zeebo.
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
