NEW!! 300 2-stroke quad, heres the speks
heres a link with a pic, looks wild!!
Engine
Displacement
299 cc
Type
2-stroke, reed valve intake into lower crankcase
Number of Cylinders
One
Cooling System
Water Cooled
Bore x stroke
72x72
Carburetor
Keihin PWK 38
Clutch
Multidisc in oil bath
Gearbox
6-speed
Ignition
Kokusan digital
Transmission
Chain
Lubrication
Engine
Mixture
Frame
Front Suspension
Independant w/ 2 Ohlins shock absorbers
Rear Suspension
Progresive rod system w/ single Ohlins shock absorber
Brakes
Front
Two 260 mm disc Nissan calipers and pumps
Rear
Disc w/ Nissan caliper
Wheels
Front
Aluminium 5.5x10" rims
Rear
Aluminium 9.5x10" rims
Tires
Front
21 /7x10"
Rear
22 /7x10"
Controls
Domino throttle cable grip
Kick Start Pedal
Folding pedal in forged aluminium
Brake Pedal
Forged aluminium with folding tip
Emergency stop system
Engine
Displacement
299 cc
Type
Number of Cylinders
One
Cooling System
Water Cooled
Bore x stroke
72x72
Carburetor
Keihin PWK 38
Clutch
Gearbox
6-speed
Ignition
Kokusan digital
Transmission
Chain
Lubrication
Engine
Mixture
Frame
Front Suspension
Rear Suspension
Brakes
Front
Rear
Wheels
Front
Rear
Tires
Front
21 /7x10"
Rear
22 /7x10"
Controls
Kick Start Pedal
Brake Pedal
They HAVE done away with that quad. Dirt wheels actually tested one, in one of there back issues. I know it sucks they did away with it. Sorry to let you guys down but it had to happen sooner or later. In 99 they actually had pics of it on there website gasgas.com and if you go check there you will see is all gone not even a pic of what could have been one awesome quad
