IN NEED OF CLUTCH REPLACEMENT HELP!!! PLEEEASE!
Old Oct 31, 2001 | 09:09 PM
Mr350X's Avatar
Ok, Im in a hurry here. Im replacing the clutch in my 350X.
Im all the way to removing the last bolt to get the plates off.
I already removed the 4 spring bolts, and im seriously stuck here.
I cannot get this big main center clutch basket/pressure plate bolt off.
Is this bolt reverse threaded or what? I simply cannot get it to budge.
I called my local Honda dealer, and one of the guys told me that I NEEDED this special honda tool that holds the sprocket so that it dosnt spin while your trying to get the bolt loose. Ive solved that problem by locking the rear wheels, and putting the tranny in 6th gear.
So, my question is, is this bolt reverse threaded? or do I need to BANG on it harder?
Old Nov 1, 2001 | 09:31 PM
Mr350X's Avatar
Yea, thanks people. Good thing I DID figure this out on my own.
Old Nov 1, 2001 | 10:06 PM
crhye250r's Avatar
Glad to hear that. I read this and didn't know anything about it so i didn't respond. Glad to hear you got it going. What did you end up having to do?
Old Nov 1, 2001 | 10:56 PM
Need4Speed's Avatar
You can't always expect a reply within a day on here. Some people don't get on here every day.
Old Nov 1, 2001 | 11:51 PM
Mr350X's Avatar
Need4speed: I know, I was just in a big hurry because of the sircumstances.
250R: I talked to a buddie of mine, and he told me that it was NOT reversed threads.
So I just got a breaker bar with LOTS of leverage! (about 3 foot bar) Broke her loose right away. Now Im just waiting for my new clutch kit.....
-Matt
Old Nov 2, 2001 | 09:46 AM
biggy's Avatar
matt you dont need to take the basket off !! only the plates and fibers ,springs
Old Nov 2, 2001 | 12:05 PM
Mr350X's Avatar
I didnt take the whole basket off. There is the 4 spring bolts, took them off.
Then, in order to get all the plates off, I had to remove a large pressure plate bolt. Pressure plate comes off, and all the plates follow.
Question: Anyone know tight the spring bolts must be? Torque specs?
-Matt
Old Nov 2, 2001 | 06:01 PM
Lasher's Avatar
Rather than locking up the rear wheels and putting it in 6th gear, use a penny. You place the penny in the clutch gears and the next one over. Since the penny is a softer metal than the gears, the penny is destroyed, but the gears will not get a mark.
Just make sure you take the crushed penny out when you are done.
Old Nov 2, 2001 | 07:48 PM
KeyRacing's Avatar
My 300ex has the same stupid clutch design as the 350x and I beleive the torque specks were 10-12 something. Not sure if it was Nm or Pounds.
Old Nov 2, 2001 | 08:13 PM
imported_juggalo's Avatar
when i had to get that clutch bolt off on my lt i had my dad crack it loose with a ratchet wrench while i held the rear brake as hard as i could.
ghost civic
Jan 15, 2020 07:43 AM
ghost civic
Jul 15, 2015 10:48 PM
clsharky
Jul 13, 2015 02:07 PM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
