how do i remove my valve stem?
Old Nov 8, 2001 | 09:27 PM
phaskell's Avatar
i got a new rim and i need to know how to get the valve stem out of my old rim to put it in the new one thanxx
Old Nov 8, 2001 | 09:33 PM
KNOWSALOT's Avatar
The Facility
You don't remove and REPLACE a valve stem. It will not be in any condition to replace when you get it out. It would never seal properly if you do. Just yank the old one out or cut it out, then put in a new one. If your dealer only carries the OEM valve stems instead of the aftermarket ones, go to an auto parts store with your old one. Just make sure the O.D. and the length is the same. Don't pay more than 2.50 for a valve stem.
KNOWSALOT
Old Nov 8, 2001 | 10:20 PM
Crawdad's Avatar
Knowsalot is right, just bend the old one over far enough and they will usually crack and break off. If not just cut it. Put a little dishsoap on the new one to lube it a little and pull it through the new rim, while rocking it from side to side.
Divergent12
Dec 30, 2017 08:33 PM
Sportsman850
Jul 31, 2015 04:25 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
1966F100
Jul 12, 2015 03:01 AM
Unzzy66
Jul 11, 2015 10:01 PM
